Still Export Problem
  • Still Export Problem
    Is there a better way to export a still image from the timeline? Currently using .tga>Frame.
    The skin tones of my export is washed-out and unacceptable to use on the timeline again.
    Thanks, Rusty
    Field/frame settings won't change the color, and stills are RGB.
    Best you can do is color-correct - either after or before.
      Thanks, Rusty
      Since Edius exports whatever it sees, still images grabbed from video might not look good on a computer monitor...that's just reality.
        Dont know if it makes a difference to the quality, but i always chaneg projejct settings from HDV to Full HD, just so i can work in square pixels.
          Ug!
          I don't like any of those answers!
          From previous posts I figured I can make a freeze frame by trimming a single frame and setting the speed to 1%. 100 frames, if I need more time, I can copy/paste as required.
          Rusty
            Hi,
            I always use Topaz Moment with exceptional results.
            Greetings
            Uli
