How do you do this with edius 5.12?? Im drawing a complete blank?!?
Split Screen with softedge?
you can try alpha custom map and use the keyframes to get this and use sharpnes tho soften your edgeParanova Films
Cali - Colombia
http://www.paranovafilms.com/
Just put two clip one on top of each other and drag a Border Wipe transition from the 2D Transitions group, and put it in the gray area of the clip on top and drag it all the way out to the right and double click the effect in the information pallete and keyframe start and end at 50, and check soft border box and adjust your width. (-:I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
