Burn To Disc Mystery
  • Burn To Disc Mystery
    If I have a 4 hr. DV project I need burned to disc with Timecode, the simple solution (it seems) would be to render a single file, bring it to the Time line, cut it in half and burn it.
    But, nooooooo!
    E5 seems to think there's still 4 hrs of footage (remember. the file has been cut to 2 hrs.) and will only want to burn to a DL/DVD!
    So I render a 2 hr. file and it's fine.
    What's with that?
    I recall a similar issue with "Phantom Footage" in Sequences before.
    did you mark in and out?
      Ok, now it works fine, marked or not!
      Using the original 4 hr file.
      Thank gawd the client has gone home.
