3D picture in picture
  • 3D picture in picture
    i would like to copy a 3d picture in picture setting to other clips. how do you do that?
    Simply pull the 3-D PIP setting from the keyer track down into your list of keyer 3D effects...Rename it as you choose. Then it can be used on any clip (remember it goes on the keyer line).
    Or simply grab it from the keyer on the clip where you have created it and place it on the keyer track of the new clip where you wish to use it.
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
      There are two ways:
      1. if your original "3D PIP" effect is selected, just drag the effect from "info palette" to the clip
      2. You can save the 3D PIP effect as a "user preset" rename them and use it like a "customiced effect"
      Eric
      English is not my native language
      ___________________________________
      System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
      System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
