Movie Factory 7 recording speed
  • Movie Factory 7 recording speed
    Hi all,
    I'm using Movie Factory 7, supplied with Edius 5.
    Anyone of you can change the recording speed? If i click on the big "I" before starting to burn my dvd, I can see the recording speed set to Maximum and it isn't editable...I tried on all my computers and the problem is there..so I think it's a software bug....any solution? Have you the same problem?
    I noticed that as well, that is why I stick to burning in edius.....I usually burn very slow...1x, 2x, 4x is my max.......don't get complaints....but in MF7, that feature is not working....worked in v.6 though...so, if I have need to use MF, I use v.6
