problem with trial version of edius 5
  • problem with trial version of edius 5
    Hi there. I've just installed the trial version of Edius 5 and am wondering why the burn to disc function would not be functional. Is this a limitation of on the trial copy.
    forgot to add that my project settings are 720p 25fps
      That's sound like a HD project. You are burning to DVD or BluRay? DVD can't cope with HD.
        Burn to Disk only works when the project setting is interlaced, yours is progressive, so no go
          thanks for those helpful responses. I didn't understand the difference between Dvd and Blue ray. I've burn't my project using a dvd standard and the results are pretty good.
            if your source material is HD and you have a Blu-ray burner, then you can make a Blu-ray from the timeline, it looks far better than DVD
