Hi first time poster here and you guys seem to be the most knowledgeable people about Edius - so figured you'd be the ones to ask (go easy on me!)
Ever since upgrading from Edius 4 to 5 (and even with the patches for 5) I've found Edius takes significantly longer to launch. Edius 4 would spend perhaps 20 seconds on the splash screen, whereas Edius 5 is taking several minutes.
I've not changed my hardware configuration and assume perhaps it might just be 5 being more demanding hence taking longer - but i'm just checking to see if this is common and something i'll have to get used to or if there's something I can tweak to sort this out?
I'm running a Dual Xeon setup with 3GB of ram and XP 32bit.
Thanks!
Thanks!
