Xplode render settings
  • Xplode render settings
    Ok so I've been editing for 4 years on my system and I have
    2 questions about the render settings for xplode 4 config.
    1. What is the difference between draft mode and high quality mode?
    The guy who set up my system told me to always leave it on
    draft mode.
    2. Should the renderer be on my graphics display card or
    3D universal render? I don't know what the difference is?
    Thank again I'm having a busy night on this forum tonight!!
    Using Edius 6
    if you want to produce results to match the stone age, leave it on draft mode :)
    otherwise leave it on high quality mode
      But what is the difference? Does it affect the final product?
      Using Edius 6
        of course it does, draft quality allows for faster renders so you can check to see if you like the effect
        draft render was designed for the days when computers were really slow
          Well my computer is not the fastest in the universe as you can see.
          Will permantely changing it to high quality affect it much or should I just leave it on draft mode then change it to High quality before
          export?
          Using Edius 6
            I meant to say will putting it in high quality mode slow my computer down more? It's almost 4 in the morning here and I'm getting
            cross eyed.....
            Using Edius 6
              no, it won't slow your PC, it only determines render speed, so always leave it on high quality, it is the default of the program
                ok that is done!
                Using Edius 6
                  You know I feel like a jerk. You would think I should know all this stuff,
                  but all the technical stuff was never taught to me and the Edius
                  manuel doesn't go into much detail about buffers,rendering etc..
                  So if it wasn't for you and this forum I would still be at step 1.
                  There is so much I'm sure I still don't understand like when exporting files when to use Canopus HQ Avi Vs DV avi etc... there just isn't any
                  in depth info to explain a lot of this stuff....
                  Anyway both my video drives even though they are only 39% full
                  are telling me I should defrag the drive, but I don't like defraging in the middle of a job... What's your opinion?
                  Using Edius 6
                    Canopus HQ preserves more quality than DV but uses more disk space
                    I never defrag a video drive, not even in between jobs
                      Canopus lossless?
                      So you just reformat?
                      Using Edius 6
                        Originally posted by lauri View Post
                        Canopus lossless?
                        Canopus Lossless is even better than HQ but way larger in file size
                        no, I don't reformat, because when a project is complete, I copy and paste it to the storage drive
                        then I delete it on the video drive and guess what, the fragmentation is gone
                        video files cause very little fragmentation in the first place, because they are large
                          Video files cause little fragmentation because they're not extended, shortened or modified. The only time they get fragmented is if the free space is already fragmented when it is copied or captured.
                            Brandon, so why does it come up that my video drive needs to be defrag?
                            Lauri
                            Using Edius 6
                              It might have a few fragments, or if you have other stuff on the drive, it might be reasonably fragmented. Once fragmentation starts, it accumulates quickly unless you get rid of stuff on the drive.
