Edius AAF to Nuendo
  • Edius AAF to Nuendo
    Guys,
    is there any visible tips/aproach of how to export Edius sequnces correclty into Nuendo through AAF to avoid from mistiming between video and audio track? In my case, Edius 5.12 / Nuendo 4.3.0 audio drops behind video a little bit. I used to have the following workaround of this issue,
    - Project settings: Generic OHCI HD 50Hz 1440x1080 50i 48kHz 2ch
    - I have rendered my sequence w/ adding one into timeline
    - Export -> Type 2 (RFC1738) w/ "Compress and copy a clip" for both Video and Audio
    What else needs to be done, even something in Nuendo?
    Workstation: Dell Precision T5500 | Edius NX HD Suite w/ Bay | OS: Win7 Ultimate x64 | CPU: Two Intel Xeon X5550 2.66GHz | 48GB 1133MHz DDR3 ECC-UDIMM | Boot/Apps Drive: WD5002ABYS 7200RPM | Video: 2x500GB Raid 0 (1.0TB) | Graphics Card: NVIDIA® Quadro® FX 3800 | UAD-1 | TC Electronic PowerCore Express
    Finally, being in close touch w/ my workstation, and Steinberg forum, I found the solution by self, so to those of you who works w/ both Edius and Nuendo, my tips :
    1. Start your Nuendo, also check the option of releasing ASIO driver while Nundo is working in background is switching on there, pop out Nuendo,
    2. Start Edius, do everything you'd like, than just to export your sequence/ whatever to AAF by default (Type 1), no matter either your video is rendered and put into timeline or not; within the AAF directory, you get a few files, .mpg for video and e.g. AIFFs for audio tracks,
    3. Pop in Nuendo, and import your AAF, also put your .mpg into Video track by self,
    4. Enjoy!
    P.S. Please check you have the same sample rate e.g. 48KHz wherever you work, audio card, Nuendo and Edius, to avoid from audio mistiming. Also looks like Edius doesn't recognize any Fade In/Fade Out for audio within AAF as distortion is happenned, just to remove and let Nuendo to make your audio mix properly.
      AAF Export from Edius 6.08 into Nuendo 5.5.4
      Just looking around a proper AAF export. Comparying to Ed 5.51 it became better now, but STILL either Nuendo recognize stereo tracks as mono, or Edius export stereo tracks as mono. Anybody understands a proper way to export Edius' stereo tracks as stereo into Nuendo?
