edius neo 1.1 built-in dvd creator
  • edius neo 1.1 built-in dvd creator
    i'm still new to edius, and am trying to figure out many questions on my own. however, i still have things i just can't figure out.
    when i go to burn a dvd using the built-in dvd creator, i'm given several themes to illustrate the title and root menus. i'm more in favor of the plain, chapter only layout, where i'll add my own photo in the background later.
    what i would like to do is add as many chapters to the menu as possible. the problem is, the max allowed is only six. for the life of me i don't know why this is true; my dvd projects are about 15-20 chapters, and i would much rather fit all of them on one menu than having to flip through several of them.
    other than the drop down menu, is there any way to have more than six chapters per menu screen? or is there some other work around?
    thank you very much.
    I have no idea about Neo, but in Edius5 you can have 18 chapters per 16:9 menu and 36 chapters per 4:3 menu
    you are not allowed to use more than 18 per menu when using 16:9, it is against the DVD spec and will cause compile failure
    http://www.videoproductions.com.au/e...ton-layout.png
      ok so i tried this and ran into a few problems.
      edius neo 1.1 only allows 6 sequences per menu; this is fine, i can live with it.
      my other problem is this: for each "chapter", i denoted a new sequence. so for instance, my first dvd has 20 sequences - hence, i want them into 20 separate chapters. this worked well on the dvd creator but i have some further questions.
      when it gets to the end of that specific "chapter", it goes back to the main root menu. even though i checked the box that enables the next title to be played after the current one is finished, it still goes back to menu.
      help is very appreciated. thanks
        I have not tried Neo
        can you try this
        start a new sequence, then drag all your 20 sequence place holders into the new sequence, then add a timeline marker in between each
        now open DVD creator and delete all sequences in the movie tab, then load the new sequence only, in the style tab, disable title menu and you tick chapter menu, this should give you the best result
