I am trying to use the print to file MPEG Generic to create a file for over the air video. We are editing in 4:3 and want to air 4:3. If it is played from the timeline it looks good, but when it's printed to file (.mpg) it makes everyone look short and fat. Any suggestions for settings or how to correct this problem.
MPEG Generic Print to File problem
is your project setting 4:3?
are you exporting using a 4:3 mpeg preset? remember to enable conversion to see all presetsAnton Strauss
I viewed the statistics in our Stradis MPEG software and the Horizontal is 720 and the Vertical is 480 which is correct. The aspect ratio says 9:16 compared to other videos I know display properly that say 3:4. This is just more information I am trying to pass onEDIUS 5.5 NX PCI-Express SD Dell T7500 Xeon E5504 2GB RAM NVIDIA Quadro FX 580 Windows XP Pro
Originally posted by ablandford View PostWhere are the settings for the presets?? We are currently using Edius Neo 1.01, but are upgrading to Edius Pro 5.1 in the next week or two.
let me know if you can't find it and I will supply pictureAnton Strauss
Hi Anton
ablandford is here in the false (Edius) forum....
ablandford wrote: We are currently using Edius Neo 1.01
In Neo1.01 ..... there is no Exporter like 5.12 or Neo 2.xx
screenshot from (my test-Neo 1.01)
step 1
step 2
friendly greeting, from the "picture-man" ......... located in CentralEuropeCentralEurope aka Hans
Originally posted by antonsvideo View Postat the bottom left of the export dialog, tick "enable conversion", then all presets will show
let me know if you can't find it and I will supply pictureEDIUS 5.5 NX PCI-Express SD Dell T7500 Xeon E5504 2GB RAM NVIDIA Quadro FX 580 Windows XP Pro
