DVCAM PRO Import Question
  • DVCAM PRO Import Question
    I use Edius NX for HDV + Exp and Edius 5.12. I don't do very much importing of video into my edits.
    I have a client that has (SD footage I believe) shot in DVCAM Pro format. Is it possible to import this directly into Edius? What other formats could I have them convert it to that would give the best quality in Edius?
    I should also note that they will be sending me the files on CD/DVD not tape.
    Thanks!
    Sincerely,
    Mike Truly
    Truly Media
    970.349.5651
    www.trulymedia.com
    System1: Edius 7.41|Storm Mobile|Dual Xeon 3.1 (20 cores w HT OFF)|128GB RAM|Dual 512 SSDs|7TB RAID5|Dual Quadro5000s|Win7_64
    System2: EdiusNX+Exp|Edius 6.03|Procoder3|XP32|Dual Xeon 3.6|4GB RAM|U320 RAID0 15K
    I don't think there is a dvcam pro format. But dvcam edits just fine
      Thanks very much Steve. I have since found out that the file being sent is an AVI file encoded with a Matrox codec.
      Any known issues with having a Matrox codec on an Edius system?
      Thanks!
      Sincerely,
      Mike Truly
      Truly Media
      970.349.5651
      www.trulymedia.com
        Install the Matrox codec pack on your system and all will be fine.
          Thanks Steve... will do.
          Sincerely,
          Mike Truly
          Truly Media
          970.349.5651
          www.trulymedia.com
