5.1 audio in Edius... how to proceed?
  • 5.1 audio in Edius... how to proceed?
    Hello, guys!
    I'm wrapping up a project (that one with the multi cam issues...in the end, everything went OK) and the orchestra staff is sending me the 5.1 audio from the concert.
    In which format should I export the project, so I can author a DVD with the 5.1 audio? I never done that before with Adobe Encore or DVD Studio Pro...
    Originally posted by AlexandreCardoso View Post
    Hello, guys!
    For these cases Advanced DVD Authoring, you can simply export your edited video EDIUS to MPG Elementary Stream (*. m2v), this kind of split the video file and audio separately, allowing you to synchronize and collect several types of audio at once either: LPCM Stereo, AC-3 Stereo, AC-3 5.1 Channel ... imported in the same timeline created in Adobe Encore DVD where the resulting video (*. m2v).
    CSXD2 l For EDIUS Pro 6.5
      Dont let Encore re-encode the audio or it will turn it into stereo!
      Supermicro X6DAE-G2 - 2x Dual Core Xeon 3.2 Ghz, 4G ram, SP Breakout Box, Nvidia GTX260, win xp pro. CS4. Mackie HR824 audio monitoring, Audient ASP510 Surround Sound Controller + smaller bits..
