If many other applications supported the .CSV file that Edius uses, it'd be really cool...because we could export this file and just import it into an authoring app and have the chapters show up in a second.
Using CSV files as chapter points from EDIUS
Originally posted by STORMDAVE View PostIf many other applications supported the .CSV file that Edius uses, it'd be really cool...because we could export this file and just import it into an authoring app and have the chapters show up in a second.
and I import it into DVD Studio Pro,
it shows up in a second alright.
Bill :o)
Bill :o)Windows 10 Pro 64bit, Edius 7.53, Antec DF-85
Corsair 850Watt P/S,ASUS P6X58DE,
Intel Core i7 960 3.20 Ghz Bloomfield,Corsair 12 GB RAM TR3X6G1600C8D-R,PNY GeForce GTX570
WD 600GB 10k RPM System Drive,
WD Caviar Green Video Drives 1GBx2,G-Raid 2GB Backup Drive,Pioneer BDR-206 Blu Ray Drive
Originally posted by jerseymike View PostHow did you get that to work? I tried but it won't import into DVD SP.
Originally Posted by Bluetongue:
I remove the first column with the marker numbers (1 to 6etc) and then save as a txt file...
Bill
Hi Mike,
Sorry I forgot to mention that I need to save it as a txt file as well :(
Hi Bill.
I tried saving it as a text file but when I try to import it into DVD SP as a chapter list it says it imported 0 chapters :(Windows 10 Pro 64bit, Edius 7.53, Antec DF-85
Hi Mike,
*1 - Open the .csv file in Excel
*2 - Remove the first column with the marker numbers (1 to whatever)
*3 - Save as a .txt file, if your doing this on the Mac,
save it as a windows txt file.
This is all I do and it works fine.
Let us know how you go.
why not export direct to text file from Edius? makes no sense to export to CSV and then convert to text file
I do this daily and use the text file direct in DVD Lab ProAnton Strauss
Originally posted by antonsvideo View Postwhy not export direct to text file from Edius? makes no sense to export to CSV and then convert to text file
Wouldn't the Edius Marker Exporter plug-in make this job a whole lot easier?
http://www.matsab.de/markerexporter/...ExporterEN.htm
that's what I use and I assumed that everyone is using the marker exporter plugin? its been around as long as Edius
then again all this info was deleted with the old forumAnton Strauss
That exporter is easier but you don't get the 'comments' of the markers.
Having the comments in DVD Studio Pro makes it quicker for me to connect the correct button on the DVD to the correct marker.
Thanks !!!Windows 10 Pro 64bit, Edius 7.53, Antec DF-85
