ntsc to pal project?
  • ntsc to pal project?
    I have a quick question. If I open a PAL preset/project, then drop an NTSC video on it's timeline, then burn a dvd, is the resulting dvd PAL?
    yeap... it should be
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
      Audio sync might be an issue though.
        Thanks for the replies, guys. I guess the best way would be to just try it, but I don't have a PAL dvd player. I'll try it when I go to Malaysia.
          I have done this many times either way...PAL>> NTSC...NTSC >> PAL and have so far had no issues regards audio, durations upto one hour have been fine, not gone beyond that.....Edius actually does an ok job at this, if you need higher quality I think older versions of procoder faired much better than newer ones and TMPEG Express I think was very good and Antons recomendation IIRC.
          Regards
          Dave.
          www.nakedeyedv.com
            yes, Procoder is the troublemaker, it will cause audio to go gradually out of lip sync
            T4 Xpress is the best for converting
            export Edius NTSC timeline to Canopus HQ and then open the HQ in T4 and convert to Pal using these settings
            http://www.videoproductions.com.au/html/tmpeg4.html
              Thanks for the tutorial, Anton! Fortunately, I do have TMPEG 4.
                welcome to the A-team
