If I change a template in the burn to disc program.ie background and frames and I come up with a look. Can I save it as a template? If so how?
Burn to disc templates
Are we talking about the same thing? A problem saving them or customizing them? Im just talking about changing the background or the frame through the settings menu.Randy
I've wanted to do the same thing. What I end up doing is save the edius project under a new name (dump the old video), and load that when I want to add new video (of course save the new project as something else). As long as there is video on the timeline, the template should open under the project.
o.k. sounds workable. hopefully Edius 6 will be better in this department. I thought I was being mis uderstood it was like I was trying to get into the code of the templates. so you cant save template that you customized?! o.k.thanks for your workaround.Randy
