I have a new HD monitor and have it hooked up the the component outputs of my EdiusNX + Exp. The picture looks fine but I was trying to make sure I had the right settings within Edius.
I looked in the helpfile and because the search is so poor (Is the helpfile going to be improved at all in 4.5?) I could not find a section on these settings. I currently have it set to SMPTE rather than Betacam (which I'm assuming is correct but can find no description of the settings). I also have it set to Multi-monitor with setup.
What's the difference between SMPTE and Betacam settings?
Thanks!
Thanks!
