Sorted, the timeline window was just a wee bit bigger than it should be.
Timeline needle not going far enough to the right
Fractal Design Define XL R2 Full tower- Asrock Z490 Taichi - i9-10850K -- 250GB 860 EVO- 32GBVengeance LPX- Blackmagic IP4K-- Geforce GTX 1070 Founders Edition -- EVGA G3 850 PSU-- Corsair H100i Pro XT- LG Blu-Ray writer- MxM PCI-e Reader-- EDIUS X WG- Win 10 Pro 64bit.Tags: None
I bet ==> you have work in the past on two monitors ??
and now, you work with one monitor??
if it is so ==> try [Shift] + [Alt] + [L] ==> for the "default" Layout
__________________________________________________ ________
please, excuse my "fractal" english ......friendly greetings from CentralEuropeCentralEurope aka Hans
Thanks, well, your half right :)
I still have two monitors. i must have enlarged the time Line window a tad to much by mistake somehow so a small portion of the window was missing.
Thanks for looking and thanks the for tip.Tony
Originally posted by pjsssss View PostSo once you have your layout just right, Look under GV >Layout>Save Current Layout>New and save it. Then the next time something is screwed up you can just restore the layoutTony
