I'm Shooting HDV footage, and using 4.13 Edius, A friend of my using Vegas uses "gama" to increase the brightness of some wedding footage of mine. (it worked great), what would be the best steps within Edius to get equal results. Gary.
Help with Brightening footage
Try this I use this to brighten footage taken on cloudy days
Under Colour Correction select Colour Balance and try the following settings
Chroma set to 17
Brightness set to between 15 and 40
Contrast set to between 12 and 21
try various combinations it certainly makes a difference
The Alternative is the YUV curve another name for GAMMA but I find it a little daunting to use, EDIUS does not seem to have a GAMMA correction as such, Even on Premier and Media studio Pro I used the Colour correction filters as GAMMA seems to be either too dark or too light, maybe its just me!
Sorry for the strange accent on Colour/color its Ausy English
Hope this helps
Another nice trick from the old forum: duplicate the clip on a superior track and apply a screen-keyer to it. Adjust with the rubberband => works very good.Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
I just tried the Screen keyer, and it works really well. My question is this: exactly what does the keyer do? It isn't even mentioned in the Reference Manual. For that matter, none of the keyers are explained either in the program or the documentation.
If you ever used Photoshop's blending options then you'll understand what each one does :)
Here's a site that explains them:
http://www.arraich.com/ref/tool_blend_modes.htm
This one is for photoshop, but very similar to what Edius uses.
I don't know how old this thread is but I'd like it revisited.
I too have a hard time in EDIUS working out the gamma correction- does it exist under different formula?
For instance- I learned this tip off a training DVD for Sorenson Squeeze.
Apply to source a filter with +10 contrast -5 brightness & +35 gamma
I tell you what, it looks brilliant!!! How can I achieve this in EDIUS?
EDIT: You can change the brightness + contrast in ProCoder 3 then add a gamma filter but (the gamma) it doesn't have same values as Sorenson- in fact I have to reduce the default gamma slider a bit, still looks great.Last edited by shueardm; 11-28-2007, 01:47 PM.
Originally posted by shueardm View PostI too have a hard time in EDIUS working out the gamma correction- does it exist under different formula?
It works as a gamma control. bri, contrast etc all in one.
Thanks for this one Anton!Claire
Originally posted by Bart View PostAnother nice trick from the old forum: duplicate the clip on a superior track and apply a screen-keyer to it. Adjust with the rubberband => works very good.
TonyTony
Asrock Z68 Extreme7 --i7-2700K --EDIUS 8.5WG--HDStorm+ --16GB Kingston HyperX--GTX 560Ti--AX850 PSU--MxM PCI-e Reader--Win 10 Pro 64bit
Look in the Effects Pallet > Keyers > Blend
You can also use the rubber band to adjust the amount of "brightness" added.Rusty Rogers | Films
