I have a title slide in 2v and original video in v1. The title has a scaling effect using 3d pip. When I render the file the title either disappears of the video goes away. Left unrendered it stays but then the audio is distorted. Any ideas how to create the effect of type zooming in without these complications.
title mortion pro and 3dpip
Have you try just using TMP fx to do that instead of using 3DPIP? or try using Layout tool instead of 3DPIP, maybe something is not right with 3DPIP for this particular fx.I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
Which command are you using for rendering?
Btw you can scale with the layouter which is less taxing on your system and you can also do in Tmpro.Steve
