I've been through the steps described here to try to get a DVD that I made with Edius 5 to capture to the bin but all I end up with is a jammed computer. At least the mouse pointer still moves.
I get the message that the file is successfully saved and the disc in the drive never stops spinning. I can only play a small random section of the file however it will only play while the disc is in the drive.
I have clicked and unclicked PTS in plugin settings.
I don't know where to find 'analogue capture from DVD player'.
Once I remove the disc then I get a full jam and i have to shut the computer down via the main switch.
