Dear Forum
I am noticing some very low level fizzing noises in the DVD exported VOB files when exporting from Edius 4 Pro and ProCoder Express.
Here is a sample with the gain turned up.
EdiusProCoderEx_SoundArtifact
The source files in the project sequence are pristine 48k 16 bit files so should not need any "encoding" further, but they seem to be contaminated with this low level noise. Playing direct from the sequence in Edius is pristine.
Any ideas why this is so and how does one fix it. I tried to install the update for ProCoder Express but it wants a serial nr and I don't have one, only an Edius 4 Pro Serial nr.
Regards
David Spearritt
http://www.lodestarrecordings.com.au
Regards
David Spearritt
