Capturing DV with IEEE1394 Issue
  • Capturing DV with IEEE1394 Issue
    I have Edius 5 and cannot capture through my IEEE1394 port. I have tried the onboard motherboard port and a different card as well. It appears to link to the VCR and the controls for play, stop & pause seem to work but I do not see any picture or hear sound.
    Any ideas?
    Please more infos ==> OS \ Project settings \ Cam
    if you are on Win7 ....there is a know Windows7 issue
    it need to >updating< the win7 1394 driver to a "old" Version
      Win 7
      OHCI SD NTSC
      Panasonic AG-DV1000 VCR
      You mentioned on Windows 7 I need to get an older driver. What is the process?
      The driver was updated automatically when I installed Win 7?
      Thx!
        maybe, eventually, it helps..... for you
        here in german speech area it helps, but not for all User with 1394 \ win7 problem
        delete the 1394 driver
        restart win7
        win 7 found new hardware
        manually (by hand) for Texas Inst. (or NEC or your chip) ==> choose the 1394 driver (old)
        restart win7
        I hope you can understood my "curios" english
        _____________________________
        friendly greetings from CentralEurope
          Do NOT delete the driver, delete the device from Device Manager:
          http://ediusforum.grassvalley.com/fo...2&postcount=19
            Update the OHCI driver with the "Legacy" OHCI Compliant one. Don't let Win 7 automatically install a driver. When Win 7 asks you to choose the location of the driver. Choose "select from a list" and select the "legacy" driver. This should take care of your problem. I had this same problem and using the legacy driver fixed it.
            Tom Koveleskie - Director/Producer/Editor
            Quarter Town Films - Independent Feature and Documentary Films.
            Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
              Thanks, the Legacy driver did the trick
                Thanks guys, I am up and running now....
                  now why would one need to use a Legacy driver? does Win7 no longer support standard OHCI?
                    I dont know Anton, but the drivers did not work, with DVCapture but after I installed the legacy drivers, I am up and running.....and even though I can hear the sound when I plug 9n the camera, I dont see it, neither does anything shows up in the oreview window in DVCapture until I installed the legacy drivers, so, it has to be GV., so we will just have to wait till they release their drivers for win. 7.......hope they come soon, because I am set up for 64 bit......
                      in my case, everything works out of the box, but I am using the firewire connector on the Edius SP card, maybe that is why?
                        If you have nothing better to do
                        http://www.microsoft.com/whdc/connec..._Windows7.mspx
                          well, that should stuff up lots of home users
                          more money for us :)
                            People and computers are like people and cars, "duh! whats a dipstick for?"
                            There can be a problem with the legacy driver also, sometimes you have to find out what chipset the FW is using and see if win7 has a driver for it in the list.
                              source: 1394 Bus Driver in Windows 7 ==> Updated: June 24, 2009
                              This paper provides information about IEEE 1394 support in Windows 7 so that 1394 developers can understand the new 1394 bus driver in Windows 7.
                              The 1394 bus driver was rewritten for Windows 7 to provide support for higher speeds and alternative media, as defined in the IEEE-1394b specification.
                              The 1394 bus driver that is included with Windows 7 replaces the 1394 bus drivers that were included with earlier versions of Windows.
                              This paper provides information about the differences between the new 1394 bus driver implementation and the earlier implementation,
                              as well as information about the new functionality that is included in the 1394 bus driver for Windows 7.
                              This information applies to the Windows 7 operating system.
                              friendly greetings from the "inhouse-librarian" ....located in CentralEurope
