Quick Titler problem
  • Quick Titler problem
    Hi,
    I have a problem with Edius Quick Titler in 5:12, it freezes, I have to quit with Ctrl + Alt + Delete to exit Edius, I have Win 7 Ultimate, Title Motion Pro works.
    I installed the new Edius, the same problem, there is someone with the same problem?
    I do not use Quick Titler, but I want it to work!
    Happy New Year from Sweden!
    Windows 10 PRO - 16GB DDR4 Ram - 16TB - Intel Core i7 7700K 4.2GHZ, 8MB Cache - SSD 128 -SSD 250GB - NVIDIA GeForce GTX 1050Ti - EDIUS 8.52 - AE CS4 - 1 LG W2252 - 1 Panasonic 243V - 2st Panasonic HD HC-X920 - 2st Panasonic DVX100B
    If you want it to work the answer is simple use vista or xp.
    There is no official EDIUS support for windows 7 support yet.
      I'm using Quicktitler without problems on my system, also Win 7 64 ultimate.
      Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
        Yes, Quick Titler works here too.
        However - there are some other things that I am sure they are working on - like the faint gray text against white background when using dialog windows in import operations.
        Peter
        Skanoer, Sweden
        Edius Pro 8, Imaginate 2, Intel i7 950 , 12GB DDR3, 5 TB, Windows Pro 10 Creative, 64bit, Encore CS5
          That is a Windows 7 problem not a Quicktitler problem
            I make a scroll title with Quick Titler, save it, and try to adjust the speed the way the pdf manual tells me. I have the title set to stop on screen and hold and stay in the bottom 1/3rd for 150 frames. I pull the title clip to a longer duration but that does not affect the scroll on speed.
            Is there a workaround for this issue or is this just written off as a 'feature'?
              Originally posted by Kaj44 View Post
              Hi,
              I use Windows XP, and have the same problem:(
                My Edius 5,5 currently works fine. I have no problems with Quick titlar at all. I am now waiting for the Edius 6,0.
                Have a nice day!
                  Quick Titler Again!
                  Quick Titler freezes and the program must be restarted.
                  The same thing happens if I do System or Project settings, EDIUS 6:51 collapsing.
                  It is not enough to turn off virus protection, I have to uninstall the program, then work EDIUS!
                  Now I have to buy new Virus protection that works with EDIUS 6:51, but which?
                    Nod32 v5 AntiVirus works fine
                      PCTools
                      I bought PCTools antivirus, I hope it will work with EDIUS 6:51. Right now I run EDIUS 6:51 with no problems, no dropouts since I got a new virus protection, it is only the titles that are made in Titler Pro has to be done on the Quick Titles, unfortunately.
                        what for (now removed) AV-programm exatly run in the past on your PC??
                        friendly greetings from Central€urope ;-)
                          I know that if you have a Norton (consumer) or Symantec (enterprise) AV program you need to set up a SONAR exception for the GV License Manager folder or you'll get crashes in GVLM and subsequently Edius.
