MB for SP
  • MB for SP
    I have just bought Edius SP and was about to buy the P5WDG2 WS Professional
    which was given the thumbs up by so many of you. See this thread. . .
    Unfortunately I have just learnt that this MB is no longer available.
    So now I am looking at the Asus P5K WS
    Sorry to start this discussion all over again but I really need to know if this MB will work with SP.
    I have also emailed the Grass Valley guys here in Melbourne, just waiting for a response.
    Thanks to anyone who can help (again)
    Bill :)
    GESTOS PRODUCTIONS
    www.gpvideo.com.au
    That chipset is untried afaik. It could work or it could give you trouble.
    It looks like ti only has 1x PCI-X, 1x PCI-e and 2 X PCI. So you would use all them up and left with only 1 x PCI----- that's a bit of a concern, no room for a raid card.
    Perhaps think about the Supermicro X7DA-LE which is an ATX form factor Greencreek (good) chipset dual Xeon board, so it will fit a standard case, have more slots and you only need to put in 1 Xeon, upgrade to 2 later if you choose. It would retail around $750AU though.
      Thanks Mark,
      This MB has:
      1 x PCI-E x 16 slots
      2 x PCI-E x 1 slots
      1 x PCI-X
      2 x PCI 2.2
      See here
      GESTOS PRODUCTIONS
      www.gpvideo.com.au
        OK, the 1x PCI-e slots were too small to the naked eye :)
        1x PCI-e slots are not useable for a decent raid card either, so there's still limitations.
          Has anyone tried the Asus P5K WS with Edius SP ?
          Any other thoughts would be appreciated as I'm about to build my system.
          (thanks again Mark for your help)
          GESTOS PRODUCTIONS
          www.gpvideo.com.au
            Just got supermicro x7da8 for the SP, onboard it has :
            1 (x16) & 1 (x4 in x16) PCI-Express,
            2x 64-bit 133/100MHz PCI-X,
            1x 64-bit 100MHz PCI-X,
            1x 32-bit PCI 33MHz
            6x SATAII Ports via ESB2 Controller RAID 0, 1, 5, 10 support.
            Adaptec AIC-7902 Dual Channel Ultra320 SCSI RAID 0, 1, 5, 10
            Still waiting for the memory so i can get it started..........................
            JoiCam´s
            And more
              I've been told by tech support that this board might work:
                This is working for me and my SP, but doesn't really help Mr.Bill, sorry.
                System 1 - SP with Edius Broadcast 4.54 , 2x DUAL 2.66 Xeon CPU's, Tyan 2696, 2gig RAM, Sapphire 1950PRO 2
                System 2 - RT2 MAX with Edius Pro 4.54, 2x Xeon 2.4ghz CPU's, 512meg RAM, Compaq
                  Thanks so far guys.
                  I am leaning toward the Asus because this motherboard supports the latest Intel 45nm CPU Core 2 Quad.
                  Tech support told me that this board should be OK
                  But could not guarantee anything as it hasn't been tested yet.
                  Bill
                  GESTOS PRODUCTIONS
                  www.gpvideo.com.au
