Burn to Disc
  • Burn to Disc
    I have recently lost video on playing back Bluray disks audeio is ok, i am using Cyberlink Power DVD as playback it was ok until recently. System is new so i cant roll back in case Microsoft (Vista) updates have changed something. Anyone else had this problem. All disks play ok on PS3 (not bought a Player yet)
    Also during BD output is it normal for Time passed clock to continue running whilst Time left stops this is at the 83% stage it will later re start the countdown maybe 10-15 minutes or more
    Power DVD will only play blu-ray on a primary monitor (depending on graphics card), just in case you are using 2 monitors and playing it on the second
      what for version from Power DVD did you have ??
      PowerDVD 7.3.3304 runs well with BD
      than comig pressure fom Hardwarw Industry
      and PowerDVD 7.3.3304 and higher .... no BD plays ..thats "Marketing"....
      friendly greeting from CentralEurope
        I am using PowerDVD9 Ultra and it works fine, but only on primary monitor
          That pressure was applied because Cyberlink leaked the Blu-Ray encryption keys. They fixed their shoddy programming and are once again able to play Blu-Ray disks.
            THX for the info
            have you know, what for verison was the first fixed vesion,
            behind the (unfixed) PowerDVD 7.3.3304 ??
              Thanks all it wqas indeed in use on 2 monitor and video is present when switching to primary monitor
              Has anyone come up with an answer to part 2 od question ?
                Hans its Version 7.03.4617.0
                It was bundled with LG Writer as part of cyberlink Suite
                  Upgraded to 7.3 and it now plays on secondary monitor
