3D Transition transition not Transparent
  • 3D Transition transition not Transparent
    Another question-- on my 3D transitions, where I want the background transparent (to show another video through it on a lower videotrack), the region stays black- I hve gone into the configuration window and selected transparent (the other options are there and are active when I click on them like video A, B, matte) transparent seems to "activate" but doesn't show transparent on the timeline.-- anyone with any ideas?--
    AGAIN, many many thanks for all the help---Ed
    Main System- HD Storm + Edius 7 Pro
    Win 7 (64),Asus P6T Deluxe v2 - Intel I7 - 12 G ram Gforce GTX 970 - 6 T internal-- 12 T Drobo Sata connection
    Secondary System- Edius 6- Win XP, Intel DH55HC i5 4T storage, 4G ram, Gforce GTX 260, , ADVC110
    This has been broken every since it came out, you just have to shift Q that transition and do a luma key for it to see the track below.
      Wow!-- that's nasty!-- I was dissappointed there was no option to select a BMP for the background on any-- even the old Rex Xplodes had that!
