Print to File with chapters
  • Print to File with chapters
    Do any of the print to file options carry the chapters information or is this only available in Burn to Disk
    I think it is only print to Disc.
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
      Never tried this, but I think it is only to disk as well.
        If my memory serves me correctly, there was a download...YOU will have to do a forum search for it......about a 'marker output' plugin...something like that...my have the words incorrect....I think I had downloaded it as well, but I don't install things I don't need....where you can make your output file with the chapter markers, and load the file in some other application....but like i said...you will have to do a search for it.....
          Thanks found the link
