Edius and DVD dual pass burning. I look for info
  • Edius and DVD dual pass burning. I look for info
    Hi, I use Edius 5.1 and I'd like to ask a question, please.
    If I will use dual pass option, I will get better optimization of space on DVD or I will get both, as better optimization and better image quality? I have one project on the timeline (30 minutes) and I have to burn a DVD with the best quality.
    What is your suggestion? What bitrate?
    CPU: Intel i9 7940X
    SSD Drive:
    for 30min DVD you can use the max constant bit rate which will give the best image quality
    use CBR and a bit rate of 8.1M (you can type it just like that in the bit rate box)
    also select FINE in the selection box
      I'm sorry but I don't see FINE option. Where is it precisely?
      CPU: Intel i9 7940X
      SSD Drive:
        sorry my mistake - im getting confused with MPEG file creation - all blurs into one in my head!
          In the Burn to Disc Plug In on the first page under Settings remove the auto check mark from the box's and then use the drop down list and choose 7700 for video and AC3 256 for audio....drop the video down if need be depending on how full the disc is....check the blue bar at the top.
          Regards Dave.
          www.nakedeyedv.com
