Nice things about Speed Encoder
  • Nice things about Speed Encoder
    Okay,
    I've said some rather, well, not so great things about Speed Encoder in the past, but maybe I will eat my hat while I remove my foot from my proverbial mouth.
    Yesterday I changed my RAM from interleaved to non-interleaved and in initial tests things seem to be okay! HDV projects render to .mt2 faster than RT!
    Anybody else experimented with interleaved RAM?
    Rusty
    RAM interleaving requires RAM banks be paired.
    This is in addition to any pairing of sticks in order to achieve the proper bit-width.
    Essentially, you need an even number of populated banks. If you don't, then it'll work quite slowly, if it works at all.
      Originally I had 1GB sticks in slots 0 and 2 (interleaved), Edius worked fine, but Speed Encoder crashed miserably. Sometimes taking Edius down with it.
      Same RAM in slots 0 and 1 is the only change, never a single stick.
      Rusty
        That's why I usually end up with 4GB (4 x 1GB)...
        Boards tend to be tempermental about RAM placement. RAM is unfortunately not as simple as we're all led to believe.
          Even match pair ram will *not* work perfectly in every MB. Most if not all DDR2 I read about needs voltage boosting to get them running correctly and stable. BIOS updates fix a lot of compatibility issues with different makes of DDR2.
          For Intel systems, memory speeds have little effect with over all system performance unless you run memory bench-tests all day long. So I doubt Interleaved and Non-Interleaved are going to have a BIG impact on performance when Disks are in the milliseconds.
          It's great that you are getting that performance level with Speed Encoder!
          ...Angelo
