Ive been shooting wedding with multicam setup using HMC 150 synchro by timecode. The problem is that if I have a 3 cam, file will always start with 0000. If ill place the three fottages in the bin there will be 3 0000 file in my bin. in the past I usually make a folder in the bin label as camera 1, camera 2 and etc. but the problem is that when using multicam sync using timecode, I cannot place all the video at the same time from different camera if they are in a folders in the bin. You can only sync clips when you drag all of the clip at the same time in one folder .
any workaround on this matter.
Thanks in advance
Thanks in advance
