Print to File grayed out
  • Print to File grayed out
    Hi!
    I downloaded trial version of Edius and edited my little video with it. Now I can't export it. F11 won't work and "Print to File" is grayed out.
    Can you help?
    you have an in and out marked on timeline ruler at empty section after the end of project
    you need to mark in at start of timeline and out at the end of your desired export
    I key = in
    O key = out
    X = clear existing in and out
      I key = in
      O key = out
      Thank you!
        same problem
        hello,
        I had a same problem - download a trial of Edius 7 and edit a video. After I finished, export options was grey and not possible to click on them (except batch export, but no more batch options after clicking).
        So I have found this thread, marked in and out and it was okay for once.
        Then I create new sequence and when I wanted to export, print to file and other options except batch export greyed out again and no help with clearing in and out marks and marking again..
        Please, can you help me? thanx.
        Hawlis
          can you go to User Settings, Source, Duration and make sure nothing has a duration of 1 frame except V mute
          export will fail if still image duration is 1 frame
          I remove ticks from add between in and out, as this option will get you into trouble
            thanx, but no help.. still all options in export (except batch export) are gray and not possible to click on them..
            I really dont know what can be the problem, cos first time no problem with export and I exported first sequence more than once..
            have you any more ideas?
