Help-Audio problems from 4.61 to 5.12
  • Help-Audio problems from 4.61 to 5.12
    Recently swithched from Edius 4.61 on a P4 Windows XP to Vista on a new desktop with Edius 5.12. Have been noticing when I bring projects from old system into new one that the audio meters are very hot. Not sure if the actual audio is hot but the meters are off the chart. Can anyone explain?
    Thanks,
    Ara
    what is the audio meter set to? in the mixer, you can choose various vu meter displays such as peak, average
    here are my settings
    http://www.videoproductions.com.au/edius5/VU-scale.png
      Thanks Anton. I duplicated your settings and all is fine. Can you explain why this makes a difference in the audio mixer?
      Thanks,
      Ara
        the audio mixer has user preferences, some prefer to work with the reference level, I don't, I like to see the full scale of the VU meter, so that it acts like a VU meter on a betacam deck
        the reference level is what you can change in project settings and this will impact on the VU meter display if the VU is set to reference level
