Every now and then a camera angle is a little off center from horizontal. In the past I would use 3D PiP to zoom in a tiny bit and then rotate it to correct. With HD it was easy because of the higher resolution.
Since my new laptop loaded with E5.12 is missing the 3D PiP keyer from the effects pallete (and I can't figure out why) I decided it was time to wean myself off of using 3D PiP since it is a big resource hog and RT Killer.
How can I zoom in and rotate a clip a little bit now. The zoom in is easy with the layout tool but what filter can I use (and maintain RT) that will allow me to rotate a clip slightly.
It took me 3 tries to get a stable load of software on the laptop with Vista 64 on it so I really don't want to reload Edius or anything else so reloading to get the 3D PiP is not really an option. Everything else works now and I think I can live without that one 3D PiP.
