K2 Connect Error Message
  • K2 Connect Error Message
    User reported the following error message when using K2 Connect:
    "Still proccessing now.
    Do you want to stop it and continue changing the power state? Yes/No"
    User states that when he clicks "no" the dialog box goes away, the material continues to download, but then warning comes back a few seconds later. It doesn't affect the download of material at all. Once the material is downloaded onto the computer there are usually 3 or 4 (or more) of the same message that have to be cleared depending on the download time.
    User confirms that power settings are set to Always On.
    Any ideas?
    Hi Karen,
    I sent you a PM.
