PnP playback problem
  • PnP playback problem
    I'm having trouble playing back a timeline which has 4 video tracks(3pnp).
    Playback keeps hanging up. Buffer is set to 160. I'm trying to edit a 4 camera
    project but can't get out of neutral! Any help would be greatly appreciated!!
    Danny
    If you have 4.xx forget the PIP and do multicam. It should play fine.
      Thanks for the reply Pat. Only problem is I'm using 2.5 and don't have multi
      cam.
        OHCI or GV card? What is your system? Are you prefilling the buffer?
          GV card,P4 3.06 HT,Asus p4c-800c board,1 gig ram
          Not sure about prefilling the buffer. How do I do that??
          Danny
            Danny
            shift+spacebar
              shift+spacebar doesn't help. I can't even run 2 pips without it hanging up. I
              could previously.
              I appreciate all the help but are there any more suggestions?
              Could it be my system needs cleaned up,edius reinstalled, or even a complete
              windows reinstall?
              The system actually belongs to my business partner and he has quite a few
              programs istalled which have nothing to do with editing. Could these be
              part of the problem??
              Danny
                what is the diskspeed of your video drive?
                is it SCSI, IDE or SATA, Raid or no Raid?
                  It is IDE
                  Danny
                    maybe the IDE popped back to PIO mode causing a slow speed of 1.8mb/sec
                    check the IDE controller advanced settings of the connector that holds the video drive and make sure it is in UDMA5 or better
                    provide the diskspeed result (free software at roadkil.net)
                      Thanks for helping Anton!
                      Not real computer savvy. Where do I go to get to the screen you indicated?
                        right click my computer, then left click manage
                        then left click device manager
                        then expand IDE controllers by clicking the +
                        then check the advanced properties of the primary channel, then the secondary channel (all in advanced settings tab after right clicking, properties)
                          The IDE screens are exactly like your screen shot
                          I'm checking the disk speed now(I hope)
                            My 2 internal drives speeds were
                            Physical 0---7917
                            Physical 1---6636
                            My external drives
                            2183
                            2146
                            2529
                            2259
                            Not sure what the numbers mean exactly
                              these numbers don't mean anything
                              I need to know the mb/sec (3rd result from top down)
