Simple question, I Think
  • Simple question, I Think
    Within Edius 4.13 why can't I Hilight multiple clips from a hard drives folder and open them in Edius, no problem one at a time but no way of hilighting more than one, (I've done this hundreds of times in my Old school rex edit or any other app..) Gary, one more I'm getting "soft" images in Imaginate 2.0, I didn't have this in my old system with 1.0 imaginate. (Hi-res Jpeg images in question)
    Multiple file import works in 4.5. Also you can try to rt clk the folder you wish to import the files to, and then select open folder and you can import all of them.
      I am using 4.03 and have no such problem, maybe this is a bug in 4.13?
      you can always open windows explorer and drag all needed files to the bin
        thanks guys, getting the files thru Explorer works!!!. any thoughts about my problem with Imaginate, any image I open in imaginate are soft, (I using 3-D PinP for a poor workaround, but very sharp) Gary
          all my imaginate2 with "service pack 2" projects are sharp in Edius 4
          I don't render in Imaginate, instead I open the IVT direct in Edius, this lets me lengthen and shorten to speed up or slow down as I need
            There is another thread on here about the Imaginate files you might want to read.
