Why is it not setting % 100 ?
  • Why is it not setting % 100 ?
    i can never set audio bar % 100 when i edit some moments on it... why is that ?
    grey point = % 96.. white points = % 47
    and if i move grey point a little bit up, it says % 122 ...
      Did you try to hold CTRL and position it?
        no let me try
          oleeeeyyyy thank you very much did it :D
            @ nitrococuk
            you are sure, you have the latest "Edius User Reference Guide 5.1" with 790 pages ??
            round up page 645 is this "dragging the point while pressing [CTRL] feature,
            and a lot other "rubberband -fearures" sufficient described
            example screenshot:
              Originally posted by CentralEurope View Post
              @ nitrococuk
              example screenshot:
              no i dont have it
                In assumption you have registred your Edius 5
                your user account ==> Product-related Downloads ==> EDIUS v5 ==> EDIUS v5 Documentation ==>
                EDIUS Software v5.10 User Reference Guide Released: 04/11/2009 ==> (Filename: EDIUS51_User_Reference_Guide_ENG.pdf \ Size: 47.1MB)
                in short word 's ==> on the sam place, as the "free updates" to 5.12 are aviable.......
                as picture:
                please, edit your posting (fromToday, 04:47 AM ) , and delete the Picture inside from [ QUOTE ] ......[/QUOTE] ...thanks....
                  in all versions you can click audio nodes, followed by Y key, then you can easy reset to any %
                    "Y" key? what does, it do? (in this case)
                    Paranova Films
                    Cali - Colombia
                    http://www.paranovafilms.com/
                      in my case, it opens the property palette of the audio node
                      maybe your keyboard shortcut is not set to Y?
                        Export your keyboard shortcuts and run it through the translator to get a list of what your keyboard settings are.
                          WOW and a BIG WOW! Thanks Brandon, very simp[le and easy... mine Y key does what always does: link clip, of course i know i can set almost any function to almost any keys combinations...
                          and Anton: you've been helpful (as always) just wondering if there was a funtion that i wasn't notice.
                          Thanks!
                          Paranova Films
                          Cali - Colombia
