I want a short fade in on my first clip. I don't want to use rubberbands. Is there a default fade in?
Fade in
If there are no existing rubber band points, you can use Dissolve in the 2D transitions menu.
(not both)Rusty Rogers | Films
Originally posted by Mickey View PostDoesn't seem to work.
What's wrong with the rubber band method? It is easy, easy, easy.Jerry
Fade-in and Fade-out is aviable since 4.61
The button`s are not per "default" on the timeline
result after "apply" to the timeline:
if you are a "keyboard-artist" ==> here the shotcuts:
friendly greetings from .........CentralEurope ...(the picture land *g* )Last edited by CentralEurope; 09-09-2009, 10:54 PM.CentralEurope aka Hans
Go to
Settings >Application Settings>Customize>Button then go to the top of the box and select Timeline. Look in the left hand box and find Fade In and Fade Out buttons. Drag them to the box on the right hand side (I like to have them in the very first 2 positions). Then hit OK.
This will place these shortcut buttons right above the timeline. They work by selecting the video track that you want to use, place the cursor above the point where you want the fade to end for fade in and to start for fade out. Very quick auto way instead of manually setting the points
he he, just for fun........we are both not on the preferred way, to help per "Brandon line" ==> "teach a man to fish..."
variant per "teach a man to fish..." ==> page 559 (from summary 790)
Originally posted by Mickey View PostI want a short fade in on my first clip. I don't want to use rubberbands. Is there a default fade in?Paranova Films
Cali - Colombia
http://www.paranovafilms.com/
