Where are my transitions gone?
    I am sorry to report that the diagonal line is there.
    EDIUS v5, ASUS P5E X9650 @ 3.0GHz,1x 320GB Sata II for system, 4x 150GB 10,000RPM Raid5 for video, ATI radeon HD4600 Video Card, Windows 7 Ultimate, 64bit, 8GB Ram
      download the following test project and see if the dissolve works
      http://www.videoproductions.com.au/edius5/Untitled2.ezp (right click, save target as)
        also, go and check if the 2DDissolve.FIP is in the Preset folder
          yes, the test project worked and yes, the file exists in the preset folder but I cannot get it to work for me.
          If I start a new project and select the join the transition button cannot be selected. If I slice one of the clips then I can insert a transition at the slice mark but it does nothing.
            if you slice a clip and add a dissolve, it does nothing, this is perfectly normal, because the footage before the cut and after the cut is the same
            if you can't add transition to 2 joining clips, this means the clips are fully extended and don't allow adding the transition, this is normal, so trim a bit of the end and a bit of the beginning of next clip and then it will work
            or go to application settings and untick the very first option (Extend clips when adding....)
            • #21
              I shoot continuously and then edit out the rubbish so end up with a slice between two bits of footage that are not necessarily temporally sequential. I can add other transitions successfuly to the joins between such slice bits of footage, just not the 2D ones.
              Extend clips when adding was already selected.
              I've been an Edius user for some years. This is a new installation on a Vista x64 system that previously had both an Edius and Neo trial installed on it. I suspect this may be a legacy issue from two much detritus left from the previous installs.
              • #22
                can you delete the dissolve on the project I supplied and then add it again
                does it work? if yes, then there is no problem
                btw, if extend clips when adding transitions is ticked, then you won't be able to add transitions when clips are fully extended, because there is no footage beyond the edge of the clip to allow the dissolve, so it should be unticked if you plan on doing that
                I always trim my clips, so this does not affect me
                • #23
                  ouch, I can see a complete wipe and reinstall coming along
                  you also need to delete many hidden folders
                  • #24
                    could you give me any preset for folder edius fx? i've got edius 6 and i have only Alpha map if i used old project from edius 5.
