mp4 question
  • mp4 question
    I have Edius 5.12 and did not see an mp4 setting in exporter. Can anyone tell me how to make an mp4 file and what is the difference from an mp2 file? I want to make an mp4 for Animoto or Youtube!
    Thanks,
    Ara
    Qicktime saves the day!
    Select Quicktime as the type, then on the list on the right choose "Quicktime exporter plugin", not the other QT presets.
    Next to the filename input box click on the "settings" button and select the appropiate settings you need, then save
    I7 2660k, 32GB ram, nVidia 570, Win 10 Home
      The Setting under settings I use are
      Quicktime Exporter
      Key Frames = AUTO, + Frame reorder
      Data Rate = Restrict to 5000, Optimized for Streaming
      Compressor = Encoding Best Quality (Multi pass)
      Size = HD 1280x720 16:9
      Sound I have left alone and
      Prepare for internet streaming set to "Fast Start"
      I have been using WMV using similar settings which gives a slightly smaller file but the Quality seems better this way, maybe?
      Hope this helps
