Unexpected Result after File Print
  • Unexpected Result after File Print
    I have captured a few footages using HDV Canon XH A1 and everyone knows that the output format is m2t. When I make a file print and export it in various types of formats such as avi, wmv, etc. the footage appears to be deinterlaced with some slow in motion. However, this does not happen when exported as m2t. Can anyone explain the reason behind this?
    Are you converting from the timeline?
    Does it do it if you convert your files to HQ in the Bin first?
      Yes I am printing the file from what I have edited in the timeline.
      I have neither used HQ for any capture from camera nor for file print from timeline.
        when you capture HDV, choose the HQ option, this will convert m2t to HQ while capturing
        HQ files can be edited really easy and quality is the best you can get
        editing m2t is sluggish
