Edius and SP3
  • Edius and SP3
    None of my edit stations are on the internet and they are all running XP Pro
    SP2.
    Any reason to go to go to the trouble of downloading and then loading SP3 on my NX HD machines?
    I have a 1Beyond Laptop that was on the internet and the automatic microsoft update was turned on and SP3 caused a big problem. To get the compter back up I had to restore it back before the SP3 update to get it to run.
    Ronnie
    Ronnie Martin
    Kato Video Productions
    I've had no problem with SP3 at all.
      If it ain't broke, don't fix it, (-:
      and if you are not network or internet then I would keep it like the way it is until something broke.
        Just stick with whatever you have now, and then when it's time to upgrade, go with Windows 7 (when it's out and officially supported)
          Thanks folks.... everything is running smoothly here with all machines running XP Pro SP2.
          Ronnie Martin
          Ronnie Martin
