Who uses Print to File>Blu-ray exporter for AVC...
  • #76
    Originally posted by STORMDAVE
    Just tried it on the Mac Pro setup. Same error. So yeah something's wrong with the EDIUS created files for sure.
    They aren't Blu-ray compliant that's what's wrong. Disc Creator might burn them but they wouldn't be fit for professional muxing in a BD compliant (pressing) format, same with FireCoder Blu I reakon.
    • #77
      But Firecoder Blu files are accepted in Encore CS4, so I guess its just the PAL exporter (software version) that needs fixing, as the NTSC one works fine.
      Raja Singh
      Sadha Video
      UK
      Gigabit Ethernet
      • #78
        There is a difference between a file that will mux and build in a consumer/prosumer authoring tool and a file that is Blu-ray compliant.
        Just because we can get Encore to build with a file does not make the file Blu-ray compliant, it just means we're getting closer to it. Mastering and verifying Blu-ray discs is another step completely. A member of this forum (Andrew HD) has confirmed there are multiple errors in the FireCoder Blu files with his verifyer (and I am sure EDIUS as well)
