Hi guys,
Had an interesting experience recently where I had to record a specimen in a test rig under cyclic load for a continous period until it failed. I set up a system feeding DV into my old Storm card using Storm Video as the record application but it only caputured the feed from my camcorder for three hours then quit. I eventually used Canopus DV Capture which seemed to capture happily to the external hard drive. Nearly 27 hours later the specimem broke. Believe it or not that 338 GB file loaded to an Edius 3.62 timeline but the audio was way out of sync towards the end of the recording.
I was surprised that it was out of sync. The audio is running slower than the vision so the specimem broke before any audio of it breaking appears. It is hard to tell, but the audio may be around 8 minutes behind the video, perhaps more!
Has anyone any idea why audio sync would be lost in this instance. I was under the impression that audio would be perfectly locked to the vision during acquisition. Would it be the camera file or Edius where the delay is occuring and why?
