In a previous post it was discussed that sometimes when importing music files they can be very loud and even clip. I just imported a song and the entire file clips. I know it isn't a distorted file because it came from a cd. No big deal I simply lowered the level. I just finished a project and after adjusting the audio levels (I also checked by clicking ctrl + G) everything sounded fine. Once I burned a test dvd the audio didn't sound right coming from the dvd player. Some portions we just too low. It sounded great from the timeline and the levels were right on the nose. So my question is should I change my audio reference level (in project settings)? I have it currently set to -20db. Maybe I should raise the level. Any ideas? Thanks.
Changing the audio reference level
David
DMS Films, New York
Desktop - Edius 5.5 / Intel i7 975 Quad Core 3.33GHz / 12GB DDR3 1333MHz / Nvidia GeForce GTX-275 / Vis Title 1.1 / FireCoder-Blu / (2) 27" LCDs / JVC DT-V24L1U (24" 1080p) / Windows Vista 64 - www.EditHD.comTags: None
Originally posted by DMS Video View Post. So my question is should I change my audio reference level (in project settings)? I have it currently set to -20db. Maybe I should raise the level. Any ideas? Thanks.
I still do a lot of audio there, or in Steinberg’s Wave Lab, so I can still use audio-plugin from Steinberg, TC, or Waves. When ready, I re-import the audio in Ediusvolki (Sony HVR-V1E + DR-60)
System-1: Cooler Master Midi Tower Centurion 590/ Silent Pro 700W/ Asus Sabertooth X58/ 3xCorsair CMX12GVM-Kit =12GB/ Intel Core i7 960, 3.20 GHz/ Noctua CPU-Kühler NH-D14/ Disks: Boot: Samsung 850 EVO 250GB / 6 x WD Caviar Black, 7200rpm, 64MB, 1TB/, NVIDIA GTX960/ Win-10-64bit-Pro (1709), Edius-8.53-WG + HDStorm
If I am not mistaken you can only set project reference level to reference levels which are video standard. -12/ -20 ntsc and -18 for pal.Steve
You are correct . I was also corrected here.
Never to old to learn. :)
Thanks.Steve
I tried changing the level to -12 (versus -20) in the project that is currently on my timeline. I didn't really know what to expect but I don't see any difference. Maybe I don't understand how it works in Edius?David
DMS Films, New York
Originally posted by DMS Video View PostI tried changing the level to -12 (versus -20) in the project that is currently on my timeline. I didn't really know what to expect but I don't see any difference. Maybe I don't understand how it works in Edius?
Audio in my speakers was lauder, that’s all
But I new to Edius and don’t know all the tricksvolki (Sony HVR-V1E + DR-60)
