Ok please read my post thoroughly as I need to explain my problem to you.
I have figured out how to capture HDV and edit it, and it takes a bit longer to render.. BUT What format should I select to render in?
I burn and author (on pc) with nero 6.5 (later versions of nero I have found to be full of bugs)
When I use DV I export as DV Avi as I have had problems with mpegs from edius.
In HDV there is no avi option.
The options are
**Mpeg HDV (the only option not available in dv)
Mpeg 1 (352x288)
Canopus HQ avi
Canopus lossless avi
Dolby Digital ac3
still img
pcm wave
mpeg generic
wma
wmv
hdv speed encoder
All of the above options are available either for dv OR HDV
but 'mpeg hdv' is the only new one that edius has for HDV only.
Which one should I be selecting to make a dvd?
Not sure which one I chose but it saved as .m2t and my pc won't recognise it.
I really need to sort out rendering and burning hdv to dvd
HELP!
The options are
Mpeg 1 (352x288)
Canopus HQ avi
Dolby Digital ac3
still img
pcm wave
mpeg generic
wma
wmv
hdv speed encoder
HELP!
