How To Make Audio start Fade in and Out ?
  • How To Make Audio start Fade in and Out ?
    in windows movie maker you you select the audio and just click "fade in" or "fade out" so volume get louder louder from nothing in 2-3 seconds. How do you do that in edius ? thanks
    you can:
    1 use the fade buttons on to the timeline
    2 you can add a node to the red volume line and make the fade
    3 you can use the audio mixer
      Note that the fade in and fade out buttons are not on the timeline by default. You have to add them by going to Settings>Application Settings>Customize and then choose Timeline.
        thank you very much you are great
          Re
          You can also go to the first frame of the audio, select the audio clip or track and press SHFT-V. For fade out you go to the end of the clip, move one frame to the left and click SHFT-V.
          The length of the fade will be the length you have set for durations.
