Edius support 8 channel multi-cam edit. Of course it's good.But a professional director can see 8 channel at the same time? So multi-cam edit 4 channel is enough, this feature is just a surplus,not a highlight for product,right?
About multi-cam
Yes, you can see 8 channels at the same time (If your system allows it) and one master output.
http://www.canopus.com/products/EDIU...ewfeatures.php
Go down and see the screenshot.
Yes, it is hard to switch 8x monitors at once in realtime. But with Edius and other NL Editors that support more than 4x camera multicam, you can always drag through your timeline and switch or adjust your camera cuts in non-realtime.System 1 - SP with Edius Broadcast 4.54 , 2x DUAL 2.66 Xeon CPU's, Tyan 2696, 2gig RAM, Sapphire 1950PRO 2
System 2 - RT2 MAX with Edius Pro 4.54, 2x Xeon 2.4ghz CPU's, 512meg RAM, Compaq
Originally posted by montage View PostI mean 8 cam is too much, 4 is just appropriate:)System 1 - SP with Edius Broadcast 4.54 , 2x DUAL 2.66 Xeon CPU's, Tyan 2696, 2gig RAM, Sapphire 1950PRO 2
Edius will playback in 1/2, 1/4, etc. speeds if RT is too fast.
RustyRusty Rogers | Films
Also you can resize the recorder window and make it bigger and fit it on your main screen if you have Dual Monitors and save that as a layout so you can go to it every time.
