It is hard to believe that nobody has reported on this problem, but i havent found anything about this yet:
I was testing Edius 5, using a 4.6-project file.
Everything came in fine, beside some.wav-files which are basicly synched clips from a sound device.
Thought, okey, i might have to relink (allthough they worked fine in 4.6, nothing changed, same path, no clips deleted.
When i tried to restore them, i found out, that edius is looking for the files in the exect correct directory, but cant work with them.
Trying to relink them ends up with an error message, saying they were not the same clips.
That really shocked me..i wanna do the transition to Edius 5, but i got this huge documentary project and there is no way i can use #5 having this issue..!
Having Payed for the update allready i feel a little stupid now..does anybody know about this problem and what to do?
Thanks a lot
p.s. if this wasnt reported to the "reported issues" i will copy it there..
Thanks a lot
